Product(s): | MAXSURF Stability |
Version(s): | |
Area: | Damage Stability Analysis |
Is it more beneficial to run the damage analysis to consider a higher number of adjacent zones?
All zones and combination of adjacent zones may contribute to the index A.
The more zone boundaries the ship has, the higher the predicted index will be in general, although this benefit must be weighed against the additional computation time.
