| Product(s): | SACS CONNECT EDITION |
| Version(s): | 23.00 |
| Area: | Wind Spectral Fatigue |
What is the default value for K and A parameters of the Weibull distribution used by SACS?
For Spectral Wind Fatigue, SACS automatically generates fatigue environment by assuming a Weibull distribution of the wind speed and stress. The K and A parameters used to determine the shape and magnitude of the distribution. The K parameter contains the standard deviation information since the shape of the distribution is dependent upon this parameter.
SACS use default value of K and A as below:
SACS Fatigue manual, Section 2.2.1.2 Cyclic Wind Loading
SACS Dynamic Response manual, Section 2.4.2.2.5 Fatigue Input Data
