Answer:
1. Open Connection Client (or download and install as needed).
2. Pick "Update" icon on left side of the application window
3. Select the "Manage Update" button and configure as needed
4. Press "Check for Updates" button
5. Enable the check boxes for all of the application that are to be updated
6. Pick "Update" button to start updating the application.
Suggest performing this action at the end of the day or when you plan to be away from the computer for an extended period of time.
Also, strongly recommended to reboot the computer after Update process is completed.
7. Shortcut to Bentley Software Download.
CONNECTION Client​ / Bentley License Tool​ Landing Page
