| Product(s): | MAXSURF Modeler, MAXSURF Stability, MAXSURF Resistance, MAXSURF Motions, Multiframe |
| Version(s): | All |
| Area: | Licensing |
What is the SELECT license?
For the most up to date information please refer to the following pages:
Bentley Cloud and Web Services Community pages , specifically the SES activation wiki (Subscription Entitlement Services)
Bentley User Registration and Sign in
The MAXSURF suite is licensed under SELECT Open Access. The system is designed to ensure availability. It doesn’t require hardware locks and works for extended periods without requiring connection to internet based licensing servers. It does this using a monitoring system, instead of an enforcement system.
You can review your team’s usage of the software you own via a web-based interface through a wide range of reports. These reports are available at http://selectserver.bentley.com and let you see who used what software and when. This information will be valuable to you in ensuring that you are getting best value from your software. The designated account contact for your organization will have permission to login to this server and to review these reports. This SELECTserver web portal also includes tools for managing licenses including managing check-outs, forcing check-ins of licenses, if required, and controlling access to applications.
If your recorded usage shows a peak usage that is greater than the number of licenses that you own, you may receive a Quarterly Term License (QTL) invoice to bring your software ownership into alignment with your software usage. Your Bentley account manager will contact you to discuss the usage. They will review with you whether your current license portfolio matches your license needs and can recommend a range of options to true-up to ensure you have the licenses you need. Peak usage is the maximum number of licenses that are used simultaneously within a quarter.
Here are some ways to take advantage of SELECT Open Access licensing system:
Because SELECT Open Access is a monitoring system, not an enforcement system, you need to take care not to exceed your number of owned licenses. If you have more users than number of licenses, then implement a system to ensure that users don’t start the software without checking with colleagues that the licenses aren’t already being used. There is no enforcement to limit overuse of licenses.
A MAXSURF suite license covers one user on one computer at a time. That user can run any packages from the suite and as many copies as they would like.
If you would like more information on SELECTserver , you can visit:
http://www.bentley.com/en-US/Products/SELECT+Server/
For full technical details on SELECTserver licensing, start with the Introduction section of the following user manual:
https://selectserver.bentley.com/BSS/Admin/Help/en/index.html
SELECT subscribers can access SELECT server training via the Bentley LEARN server.
