| Product(s): | AutoPIPE |
| Version(s): | ALL; |
| Environment: | N/A |
| Area: | |
| Date Logged & Current Version | June. 2017 11.00.00.22 |
The following warning appear when trying to save / rename the model. What does the following it mean and how to resolve it?
Error
E963-21: Number of characters in name cannot exceed 48
OK
As the message indicates, the file name cannot exceed 48 characters. The only resolution is to rename the model to 48 characters or less.
One known issue, a model can be renamed and opened in AutoPIPE with a file name larger than 48 characters. However the side affect was that the model would crash at any moment and not be able to print a report with a table of contents. Always confirm filename is less than 48 characters.
