23.00.01 List of Fixed Defects
Launch
- 1187070 - Fixed an issue where the displaced are of launch runners was not calculated in Launch for buoyancy forces.
Pile
- 1077207 - Improved Extended Winkler formulation of rotational stiffness curves for the analysis of Monopile structures according to PISA.
- 1099207 - Fixed an issue with scaling and interpolation of rotational soil reaction curves for PISA method analysis of monopile foundations.
Post
- 1033446 - Fixed an issue where the API RP 2A LRFD 2nd edition combined unity check with hydrostatic pressure was calculated according to API RP 2A LRFD 1st edition instead.
- 1241862 - Fixed an issue where stress concentration factors were not visible in the Postvue database when extracting from plate finite element models.
Pre
- 1216969 - Fixed an issue where an incorrect boundary condition was assigned to a pilehead joint when connected by a beam element to a joint with a retained condition (Retained/Constrained) in Dynpac analyses.
Precede
- 1205557 - Fixed an issue where Precede would not write all span definitions to the SACS model file. This affected models with span definitions in multiples of n*12+1.
Seastate
- 1202265 - Fixed an issue with DNV wake encounter effect where the CD value could be incorrectly calculated.
Solve
- 1183068 - Fixed an issue where partially fixed joints could cause errors in null space initialization. This bug only affects advanced iterative solver methods.
