| Product(s): | SACS |
| Version(s): | 16.1 |
| Area: | Joint Mesher |
When a Joint Mesher is used, double mesh is been generated for the brace member by SACS at the selected joint.
it was a well-known issue in 16.1 version of SACS. However, this issue was fixed as a part of an extensive effort to improve Joint Mesher in v23. If you like to use the Joint Mesh, we advise you to update to v23.
You can check our software download center for the latest version of SACS.
https://softwaredownloads.bentley.com/en/ProductDetails/2009?packageid=40152
