List of Fixed Defects
Data Generator
- 1009561 - Added Set Color line (SETC) support to Datagen.
GAP
- 1011761 - Fixed an issue with partially stiffened box sections causing Gap to crash.
Pile
- 1011707 - Fixed an issue with interpolated lateral stiffness soil property calculations due to incorrect overbearing pressure calculations.
Post
- 1009327 - Fixed an issue where some joint deflections were not reported in Postvue when a large number of load conditions were defined (>150).
- 1009392 - Fixed an issue where very large deflections (~10^8 in) could cause crashes in Post and Combine.
- 1009414 - Fixed a reporting issue when non-tubular code checks other than Eurocode 3 were selected in ISO 19902 (2020), Post would still report the selected code check as ISO 19902:2020 / EC3:1992.
PostVue
- 1009377 - Fixed an issue where load diagrams would sometimes extend past the Load Diagram dialog window.
- 1009587 - Fixed an issue where Postvue was displaying % of maximum units as stress units in the legend.
Pre
- 1011687 - Fixed an issue with corrosion of segmented elements with cone sections causing the errors in the corroded section properties.
- 1096348 - Fixed an issue where corrosion on tapered elements could cause a crash.
Precede
- 1009353 - Fixed an issue where member release definitions were not interpreted correctly if spaces were used instead of zeros for fixed degrees of freedom.
- 1009381 - Fixed an issue where wireframe elements were not displayed for members with undefined section properties in 3D rendered view.
- 1009456 - Fixed an issue where Check Model would identify environmental load cases as empty load cases.
- 1009458 - Fixed an issue with maximum Von Mises stress labelling for plate elements.
- 1009477 - Fixed an issue where Precede was writing the incorrect weight and length units for Metric/kg Force models.
- 1009481 - Fixed an issue with rendering some stiffener sections on stiffened plate panels.
- 1009580 - Fixed an issue where Precede was incorrectly displaying a load case selection error for analysis results including pile/soil interaction results.
- 1084857 - Fixed an issue which could cause Precede to crash when a detailed report is generated from the Member Review/Redesign dialog.
- 1086500 - Fixed an issue where legs which intersected the X or Y axis would not be identified as legs for row labeling and viewing.
Collapse Advanced
- 1088049 - Fixed an issue with incorrect reported pilehead deflection units when using metric units.
SACS Executive
- 1009490 - Fixed an issue where font sizes could appear very small in some cases.
- 1062694 - Improved SACS multirun to allow users to interact with the SACS Executive interface during analyses.
Seastate
- 1009324 - Fixed an issue where some breaking waves were not identified correctly in the intermediate range between the deep and shallow water limit boundaries. The breaking wave limit is now calculated as per DNV RP C205. H/L=0.142tanh(2 PI D/L).
- 1009558 - Fixed an issue where corrosion could be applied incorrectly to cone sections of segmented members where the cone section crosses the corrosion zone boundary.
- 1022235 - Fixed a load summation calculation error for members subjected to rotational acceleration which span an axis in Seastate.
Utilities
- 1009356 - Fixed an issue in Sesam to Sacs Converter where member releases were not being converted correctly.
Wave Response
- 1072772 - Fixed an issue with erroneous reporting of vertical hydrodynamic forces at the initial time step in neutral chart files.
