SACS Wind Turbine software provides a comprehensive set of capabilities for the design and analysis of offshore wind turbine foundation structures subject to wave, wind, and turbine mechanical loading. The analysis approach is capable of predicting both fatigue and extreme loads for the substructure and nonlinear soil foundation.
SACS-GH Bladed Strength Analysis
In this course you will learn how to generate a SACS Common Solution File from a fully coupled strength GH Bladed analysis and Post Process the results using SACS-GH Bladed Interface.
SACS-GH Bladed Fatigue Analysis
In this course you will learn how to post-process the GH Bladed results using SACS-GH Bladed Interface to evaluate the joints fatigue damage with SACS Fatigue.
SACS Wind Turbine Process - Strength Analysis (Uncoupled)
In this course you will learn how to perform an uncoupled strength analysis using SACS Wind Turbine process.
SACS Wind Turbine Process - Fatigue Analysis (Uncoupled)
In this course you will learn how to perform an uncoupled fatigue analysis using SACS Wind Turbine process.
derstand how to model and perform some In-Services Analyses in SACS Connect Edition.
SACS-FAST Integrated Strength Analysis
In this course you will learn how to perform a fully coupled strength analysis using the SACS-FAST Integrated Analysis
SACS-FAST Integrated Fatigue Analysis
In this course you will learn how to perform a fully coupled Fatigue analysis using SACS-FAST Integrated Analysis.
