Civils doesn't run after Launch( project manager fails to load)
If you run Civils Extension and it authenticates but then the project manager doesn't load please try the following.
Remove your current versions of software called Bluebeam
then install the latest version as off 01/03/22 from the link below:
https://www.bluebeam.com/download
