| Version(s): | All | ||
| Subarea: | Error | ||
When I try to import an AutoPIPE .dat model in to another .dat model it gives the following error:
Error
E522-33: Cannot complete the paste operation. The verical axis for the
current model and clipboard must be the same.
OK
The Vertical axis direction in both models are different. In order to import or copy clip one model into another, the Vertical axis direction must be identical (i.e. Y-axis OR Z-axis).
Fix by changing the axis direction in model (Tools> Model Options> General> Vertical axis direction) to be the same as the other model interfacing with.
