| Product(s): | AutoPIPE |
| Version(s): | ALL; |
| Area: | Error message |
| Date Logged & Current Version | May. 2017 11.00.00.22 |
The following error message is displayed in AutoPIPE:
Error
E521-22: Base point is not on selected range
OK
Why and how to avoid it.
As the message indicates, when trying to perform a copy command the base point (ex. B02) was not part of the highlighted red selected items (ex. beams). As a result the error message is displayed.
The base point MUST be part of the selection set (i.e. items highlighted red), otherwise the error message above will be displayed.
