| Version(s): | 2004, XM, & V8i | ||
| Area: | Error message | ||
The following is displayed when trying to open a model in AutoPIPE:
Error
E512-149: Model name must not contain space character before extension.
Please rename the model and related files.
OK
How to resolve the issue?
Press the OK button on the Error dialog screen above.
Open the folder location where your AutoPIPE Model is stored
Search for the AutoPIPE model *.DAT files (you may need to turn on file extensions for this folder).
The problem is that there is a SPACE character (shown in red below) before the .DAT file extension.
Example:
Wrong = 302242E-03(C) piping .dat
Avoidance : Modify the file name to remove the SPACE
Example:
Corrected = 302242E-03(C) piping.dat
Open the new file name and the error message should no longer appear.
