How To change the range of depths displayed on each page of a log
Explanation
The scale that is displayed on a log way need to be changed to suit a particular purpose when needed.
Process
When reviewing the Quick Log output in OpenGround Cloud Professional, 'Log Tools | Settings | Scale' setting can be used to change the range of depths displayed on each page.
Increasing the scale setting can, for example, be particularly helpful in improving the presentation of a log which otherwise appears cramped under the preview view.
