Advanced Analysis with SACS Connect Edition
SACS is an integrated finite element structural analysis package of applications that uniquely provides for the design of offshore structures, including oil and gas platforms, wind farms, and topsides of FPSOs and floating platforms. SACS software has been used by offshore engineers around the world for nearly 40 years. Many of the world’s energy companies specify SACS software for use by their engineering firms across the lifecycle of offshore platforms. Because every project has different needs, there are three flexible SACS options. Offshore Structure Ultimate for comprehensive capabilities required for typical offshore jackets, wharfs, and dolphin structures; Offshore Structure Advanced for static topside and deck analysis; and Offshore Structure for static structural analysis..
   SACS CONNECT Edition Overview
Collapse Analysis - Static Ship Impact in SACS Connect Edition
Learn how to perform a static ship impact analysis using SACS Connect Edition.
   Download the Project Workbook and Dataset to access the hands-on, step-by-step instructions.
Blast Analysis using SACS Connect Edition
Learn how to perform a blast analysis using SACS Connect Edition.
Additional Resources
Want to learn more? See the additional resources for modeling topics in SACS CONNECT Edition.
Need help? Connect with us using the following platforms:
Bentley Communities Forum
Bentley Technical Support
Bentley LEARN Server
Bentley Events
Bentley Offshore YouTube Channel
