SACS is an integrated finite element structural analysis package of applications that uniquely provides for the design of offshore structures, including oil and gas platforms, wind farms, and topsides of FPSOs and floating platforms. SACS software has been used by offshore engineers around the world for nearly 40 years. Many of the world’s energy companies specify SACS software for use by their engineering firms across the lifecycle of offshore platforms. Because every project has different needs, there are three flexible SACS options. Offshore Structure Ultimate for comprehensive capabilities required for typical offshore jackets, wharfs, and dolphin structures; Offshore Structure Advanced for static topside and deck analysis; and Offshore Structure for static structural analysis..
Learn how to model a jacket structure in SACS CONNECT Edition.
Download the Project Workbook and Dataset to access the hands-on, step-by-step instructions.
Learn how to model a topside structure in SACS CONNECT Edition.
Learn how to perform a linear static analysis in SACS CONNECT Edition.
Learn how to model loads in SACS CONNECT Edition using the load feature.
In this course, you will learn how to model the loadings acting on an offshore structure using SACS weight feature.
Want to learn more? See the additional resources for modeling topics in SACS CONNECT Edition.
Need help? Connect with us using the following platforms:
Bentley Communities Forum |
Bentley Technical Support | |
Bentley LEARN Server |
Bentley Events | |
Bentley Offshore YouTube Channel | ||
