How to change the default logo that appears on a Template
Explanation
To replace the  logo within OpenGround Cloud using a log developed by Bentley, the default logos will need to be changed within the configuration pack rather than new ones added.
Process
To set these, follow the steps below;
With no project open go to 'System | Configuration Packs'
From within here, select the configuration pack that your project belongs to, then select 'Template Images' from the ribbon;
From the 'Template Images' window select the logo that you wish to replace and select the 'Edit' button:
A browse window will then open - select your required logo file.
Note: OpenGround Cloud supports most common image file types.
