When entering data the primary controller interface allows data to be referenced correctly. However, for those entering data for the first time they can cause confusion. This recording takes a detailed look at how they work, what they are intended to do and how to get the most out of them from the perspective of the day-to-day user.
Typical examples of primary controllers in the standard data entry profiles are water strikes in the Cable Percussive profile and equipment details for Dynamic Probes. The former of these is examined specifically in this recording.
