Pre-Services Analysis with Bentley SACS Connect Edition - Lifting, Loadout and Transportation
SACS is an integrated finite element structural analysis package of applications that uniquely provides for the design of offshore structures, including oil and gas platforms, wind farms, and topsides of FPSOs and floating platforms. SACS software has been used by offshore engineers around the world for nearly 40 years. Many of the world’s energy companies specify SACS software for use by their engineering firms across the lifecycle of offshore platforms. Because every project has different needs, there are three flexible SACS options. Offshore Structure Ultimate for comprehensive capabilities required for typical offshore jackets, wharfs, and dolphin structures; Offshore Structure Advanced for static topside and deck analysis; and Offshore Structure for static structural analysis..
   SACS CONNECT Edition Overview
Loadout Analysis in SACS Connect Edition
Learn how to perform a linear static loadout analysis in SACS Connect Edition using GAP elements.
   Download the Project Workbook and Dataset to access the hands-on, step-by-step instructions.
Lifting Analysis using SACS Connect Edition
Learn how to model and perform a lifting analysis in SACS CONNECT Edition.
Transportation Analysis in SACS Connect Edition
Learn how to perform a linear static transportation analysis in SACS Connect Edition using GAP elements and Combine.
Additional Resources
Want to learn more? See the additional resources for modeling topics in SACS CONNECT Edition.
Need help? Connect with us using the following platforms:
Bentley Communities Forum
Bentley Technical Support
Bentley LEARN Server
Bentley Events
Bentley Offshore YouTube Channel
