Explanation
If you wish to edit a Picklist or add a value to a Picklist please follow the steps below;
Process
Note: If you want to edit a picklist that is across all projects make these changes in the configuration pack following the steps below from step 1.
If you want the changes to be in a single project, open the project as Administrator and follow the steps below from step 3.
- Open OpenGround Cloud Professional as the Administrator
- Go to System>Confiruration Packs>Select your pack
- Select "Manage Picklists" from the ribbon
- Once the window opens highlight the picklist you wish to edit and select "Edit". Note that you can't edit the default values if they are already linked to data in a project.
- If you want to add a new value to the list click on the orange bar where it says " + Click here to add new item" as shown below.
- Then add the value for example "PS" and a description, for example "Piston Sample". Press "enter" to commit the addition and then "Save".
Repeat this for each value you wish to add.
