How To Perform a Bulk Update
Explanation
Should it be necessary to consistently change a value across a subset of data on a project - for example, if data has been entered into the wrong column in a grid - the Bulk Update feature can be very useful.
Process
This video describes the best way of using this tool.
https://vimeo.com/162662688
