How to move all data from one project to a new one based on a different configuration pack
Explanation
You may find that a project is created on the wrong configuration pack and as a configuration cannot be changed once the project is setup the only option you have is to move the data to a new project based on the correct configuration pack.
Process
To do this you basically export the data as CSV and import to the new project.
To export the project as CSV
Open the project
Select Data>Export Data
Select '.CSV' as the file type, the file will be created as a '.zip' archive containing all the tables.
Export the data
To then import the data, create your new project based on the correct configuration
Open the project and select Data>Import data
Select 'CSV' as the file format.
Select the option to add the file
Browse to the location that contains the projects '.zip' file
Change the "File Type option to be '.zip'
You should then see the zip file for import.
