If you have a large amount of Boreholes within your projects, this can create a lot of pages with your data, you can search for a particular Borehole with the normal filter process or you can jump to a page where you know that particular Borehole will be
Open your project, and at the bottom of the screen you will see a page count
Notice the Bold 1, click into this box that shows the 1 and change that to the page you want to view and then select your Return key, this will then jump to the page you want to view.
