How to Use the Reports Section of the Project Explorer
Explanation
The Reports section of the Project Explorer provides a useful way of collating data which has been recorded in OpenGround Cloud. Test results and other parameters can be collated against the strata / geological material, for example. Set statistical counts can be performed as can statistical summaries or useful data quality validation routines introduced.
Process
The following video illustrates how Report Views could prove useful:
https://vimeo.com/228209216
