How To Create a Location Group from the Map
Explanation
Location Groups can be created within OpenGround Cloud Professional by selecting existing locations from the mapping interface.
Process
  1. Open the mapping interface as usual.
  2. Click on the 'Select' icon and select the holes required for the location group (under the default settings you may notice selected holes turn red).
  3. Click on the drop down filter above the Project Explorer.
  4. Select 'Map Selection' from the drop down (notice that the Project Explorer takes a few moments to update).
  5. Double click on the 'Location Details' grid to open it up.
  6. From this pre-filtered grid create a 'Location Group' using the button on the 'Grid Tools' ribbon.
The following video illustrates these steps:
https://vimeo.com/199970339
