| Product(s): | AutoPIPE |
| Version(s): | ALL; |
| Area: | Error |
| Date Logged & Current Version | March. 2018 11.02.00.10 |
The following appears when using AutoPIPE
Intel(r) Visual Fortran run-time error
forrtl: severe (24): end-of-file during read, unit -5, file Internal List-Directed Read
Image PC Routine Line Source
libifcoremd.dll 0F5491AA Unknown Unknown Unknown
Stack trace terminated abnormally.
OK
Why and how to avoid it?
When importing a PXF file search the file for all values = 3000
String 3000 = First connection port or point coordinates
This string should have 3 distinct columns for X,Y,& Z coordinates. As one can see in the image able the occurrence on line 11753 was found to be incorrectly formatted and thus the problem when importing.
Option #1: remove the component completely
Option #2: correctly format the coordinate locations on lines 3000 and 3020 for the affected component.
Visual Fortran run-time error messages
