Installing Launcher asks for a restart then nothing happens
If the OpenGround Launcher asks for a restart and then after the restart the Launcher is not installed and there is no prompt to continue the install it is possible you need to install Windows Updates.
To Check the Windows Version number follow the steps below.
  1. Right Click on the Windows Start Menu and Select "System".
  2. Under the section for "Windows Specifications" check the "Version"
  3. If your version is 1803 or less then you will need to install windows updates by following the additional steps below
Installing Windows Updates
  1. In the Windows Search bar enter "Check for Updates" and select this option from the list
  2. Click the "Check for Updates" Button
  3. IMPORTANT:  Also click the link below the "Check for Updates" Button which says "Check Online for updates from Microsoft Update"
  4. After installing updates, restart your machine and check your Windows version number using the steps above.
  5. Reinstall the OpenGround Launcher
