Bentley AutoPIPE V8i SELECTseries 5 (09.06.02.06) - maintenance release
Product Version
Product  Bentley AutoPIPE CONNECT
Version 09.06.02.06
Language English
Date Posted 4/3/2015 10:38:39 AM
Platforms Microsoft Windows 7 Professional or higher
Microsoft Windows 8 Professional or higher
32 or 64 bit OS
Note: Bentley IEG License Service is NOT required to run this AutoPIPE version.
Description
Bentley AutoPIPE V8i is a stand-alone, engineering application for the calculation of piping stresses, fatigue stresses, fluid transient, bowing or thermal transient analysis, flange or pipe support design, and equipment nozzle loading analysis under static and dynamic loading conditions. In addition to 30+ piping codes, AutoPIPE incorporates ASME, JSME, British Standard, European, API, NEMA, ANSI, ASCE, AISC, UBC, GOST and WRC guidelines and design limits to provide a comprehensive analysis of the entire system.
This new release provides new features, critical code updates, and enhanced product interoperability. This is a maintenance release for AutoPIPE V8i (09.06.01.11) which includes several bug fixes plus the following new features
Analysis
GUI
Import / Export
Piping Codes
Translators
Documentation
Select the following link:
Installed with AutoPIPE
Bentley ADLPipe to AutoPIPE Translator 01.00.00.19
Bentley AutoPIPE V8i Select Series 09.06.02.06
Bentley AutoPIPE Nozzle V8i 08.11.08.23
Bentley PCF to AutoPIPE Translator 01.00.00.40
Bentley STRAIT to AutoPIPE Translator 06.00.00.14
Bentley AutoPIPE Batch File Generator     1.0.0.0
AutoPIPE V8i SELECTseries 5 Setup  09.06.02.06
License Management Tool (LMT)  09.00.00.46
What is New & Changed in AutoPIPE®
V8i (SELECTseries 5) v9.6.2
The following outline identifies new features and enhancements in the V8i (SELECTseries 5) Release of AutoPIPE v9.6.2.
AutoPIPE®  Requirements
This document contains information regarding:
More detailed installation information can be found in the AutoPIPE Quick Start Guide.
Product Version
Product AutoPIPE
Version v09.06.02.06
Language English
Installation Requirements
CD drive or access to the Internet required for product installation. The minimum system configuration for installation:
Operating System Microsoft Windows 7 Professional or higher
32 or 64 bit OS
When installing the product through the installer program, the required components will be installed automatically. The contents of the Desktop Prerequisite Pack include:
Minimum Profile
The minimum recommended workstation profile for running AutoPIPE is:
Processor Intel Pentium IV or higher.
Memory 512 MB recommended. More memory almost always improves performance, particularly when working with larger models.
Hard Disk 500 MB free disk space.
Video Graphics Card Any industry-standard video card which supports OpenGL 3D graphics.
ProjectWise ProjectWise Server 8.11.7 with ProjectWise Explorer 8.11.7.133 or higher, ProjectWise Server 8.11.9 with ProjectWise Explorer 8.11.9, ProjectWise Server 8.11.11 with ProjectWise Explorer 8.11.11.
PDF Reader Adobe® Acrobat Reader 7.0 or greater
Download and Installation
To download the products, create a MySELECT CD or to complete the licensing process, you must have the appropriate roles assigned by your Site Administrator. If you have not been assigned these roles, you will need to obtain the name of your Site Administrator by submitting a Service Request at http://appsnet.bentley.com/srmanager/addcall.aspx.
If you are experiencing problems logging into your Bentley account, please contact bentley at 1-800-BENTLEY (1-800-236-8539). Outside the United States +1 610-458-5000.
With the appropriate privileges you can obtain the software as an electronic file from Web Downloads or the products may be ordered on a personal CD through MySELECT CD. Once you have installed the desired product you will need to complete the product authorization process by obtaining a license file from Bentley.
SELECT Services Online / MySELECT CD: To install from the CD, locate and run the setup.exe file and follow the online instructions.
The installation program will guide you through the process, prompting you for information when required.
If you are upgrading from an earlier version of the application, it is highly recommended that you do not install this product over the previous version.
NOTE: This is a standalone installation, no other previous installed product version is required.
Downloading the files from SELECT Services Online/Download - the download process gives you a choice to save the file to a specified location, or to begin the installation from the download area.
Network Considerations - Network drives are only supported for data files.
See the AutoPIPE Quick Start Guide (..\Documents\Quickstart_AutoPIPE.pdf) for more information on downloading and installing AutoPIPE.
AutoPIPE Functionality for QA Approvals
QA Reporting Notices
The user document numbers which correspond to this release are:
DAA037360-1/0001 - "Tutorial"
The "Acceptance Test Set" document number which corresponds to this release is:
QA25API-9.6.1
Error reports are available with client participation in the "QA & Reporting" services. Monthly error reports, open error summary lists, and details of errors corrected through respective software releases are posted as PDF or spreadsheet documents to a private QA&R Community under the Bentley Communities website: http://communities.bentley.com/.
Note: The old error reports page will cease to exist under http://selectservices.bentley.com/en-US/.
Frequently asked questions
Question 1: How do I get access to the QA&R error reports?
Answer: QA&R error reports are available on a private QA&R Community under the Bentley Communities website: http://communities.bentley.com/. QA&R subscription is required to access the QA&R error reports.
Question 2: My organization has QA&R subscription. Why I cannot access the QA&R error reports?
Answer: Access to QA&R error reports is available to the person(s) nominated to receive monthly error report notifications, by respective organizations, as listed on form 6-1-2: Contact Personnel for "QA & Reporting" Subscriptions.
Documentation
Program Help: Detailed feature information may be accessed directly from the calling application by selecting the Help command, or by pressing the Help button from any of the application dialogs. Be sure to explore the program Help for answers to your questions.
Tutorials: Documentation for AutoPIPE applications is provided online in the Adobe.pdf format. These files are accessible from the Help Menu. All documents can be browsed, searched, or printed with the Adobe Acrobat Reader. Information and how to download a FREE copy of the Adobe Acrobat Reader can be obtained from http://www.adobe.com/.
It is highly recommended that you obtain the latest version of the Adobe Acrobat Reader.
If you do not have access to the World Wide Web, please contact us so we can provide you with the necessary files for using the Adobe Acrobat Reader.
Piping Codes
This sections contains the list of piping codes, code editions supported and AutoPIPE license edition (Standard, Advanced or Nuclear) for which these items are supported.
Standard Edition Piping Codes
Piping Code Description Editions
B31.1 Power Power Piping 1967, 1986, 1992, 2004, 2005 Addenda, 2007, 2009 Addenda, 2010, 2012, 2014
B31.3 Process Piping Process Piping 2004, 2006, 2008, 2010, 2012
B31.4 Liquid Trans. Liquid Transportation Systems for Hydrocarbons, Liquid Petroleum Gas, Anhydrous Ammonia and Alcohols 2006, 2009, 2012
B31.8 Gas Trans. & Dist. Gas Transmission and Distribution Piping Systems 2003, 2007, 2010, 2012
EN 13480 European Piping Code for Metallic Industrial Piping 2002, 2010 Addenda, 2012
General General Piping Code Not Required
Extra Codes Available in AutoPIPE Advanced Edition
AutoPIPE Advanced includes all codes available in AutoPIPE Standard, as well as the following codes.
CSA-Z662 Canadian Standards Association, Oil and Gas Pipeline System 1999, 2007
CSA-Z662 Offshore Canadian Standards Association, Offshore Steel Pipelines 1999, 2007
BS 806 Design and Construction of Ferrous Piping Installations for and in Connection with Land Boilers 1993
BS 7159 Design and Construction of Glass Reinforced Plastics (GRP) Piping Systems for Individual Plants or Sites 1989
SPC-2 Swedish Piping Code, Method 2 1978
TBK5-6 General Rules for Piping, The Norwegian Pressure Vessel Committee 1990
STOOMWEZEN Dutch Piping Rule D1101 of the Rules for Pressure Vessels 1978
DNV Offshore Det Norske Veritas, Rules for Submarine Pipelines 1981, 2012
MITI 501 3-1980 MITI 501 Class III Piping Code 1980
KHK KHK E 012 Piping Code, Seismic Level 1 or 2 (Seismic Level 2 requires a KHK 2 Add-On license) 2006
RCC-M French Piping Code for Power Industry 1985
SNCT French Piping Code for Process Industry 1985
SNIP Russian 2.05.06-85 Oil & Gas Russian SNIP piping code for oil and gas 1997
ISO 14692 Petroleum and Natural Gas Industries - Glass Reinforced Plastics (GRP) Piping 2002+2005 addenda
Extra Codes Available in AutoPIPE Nuclear Edition
AutoPIPE Nuclear includes all codes available in AutoPIPE Standard and AutoPIPE Advanced, as well as the following codes.
ASME NB Nuclear Boiler and Pressure Vessel Code, Rules for Construction of Nuclear Power Plant Components; Division 1, Subsection NC, Class 1 Components 1972 W Addenda, 1975 W Addenda, 1977, 1982 W Addenda, 1983 W Addenda, 1988 Addenda, 1989, 1989 Addenda, 1993 Addenda, 1994 Addenda, 1997 Addenda, 1998, 2001, 2004, 2007, 2008 Addenda, 2010, 2011 Addenda, 2013
ASME NC Nuclear Boiler and Pressure Vessel Code, Rules for Construction of Nuclear Power Plant Components; Division 1, Subsection NC, Class 2 Components 1972 W Addenda, 1975 W Addenda, 1977, 1980 S Addenda, 1983 W Addenda, 1988 Addenda, 1989, 1989 Addenda, 1993 Addenda, 1994 Addenda, 1997 Addenda, 1998, 2001, 2003 Addenda, 2004, 2007, 2008 Addenda, 2010, 2011 Addenda, 2013
ASME ND Nuclear Boiler and Pressure Vessel Code, Rules for Construction of Nuclear Power Plant Components; Division 1, Subsection ND, Class 3 Components 1972 W Addenda, 1975 W Addenda, 1977, 1980 S Addenda, 1983 W Addenda, 1988 Addenda, 1989, 1989 Addenda, 1993 Addenda, 1994 Addenda, 1997 Addenda, 1998, 2001, 2003 Addenda, 2004, 2007, 2008 Addenda, 2010, 2011 Addenda, 2013
JSME PPC Nuclear JSME S NC1: Rules on Design and Construction for Nuclear Power Plants, Class 2 Piping 2005, 2008
How to Activate AutoPIPE®
AutoPIPE Standard, AutoPIPE Advanced, AutoPIPE Nuclear, and add-ons are are all supported on the SELECT Server Licensing. If you are upgrading from an earlier version of the product, it is highly recommended that you do not install this product over the previous version. Older versions of AutoPIPE 6.3, 8.50, 8.51 and 8.60 will run under SELECT Server XM Licensing using the SELECT Server XM Gateway Service and the older SELECT licenses. For more information on the SELECT Server XM Gateway Service see the AutoPIPE Quick Start Guide.
The AutoPIPE products can be authorized as Standalone Licenses (formerly called Fixed Licenses), fixed to one user workstation or as Concurrent Licenses (formerly known as Floating Licenses) running from a local or Bentley hosted SELECT Server.
Users who have existing Floating Licenses and wish to convert the licenses to run on SELECT Server can contact Bentley Sales Support Center from the website at http://www.bentley.com/en-US/Services/Bentley+Sales+Support.htm. The following information is required when requesting SELECT Server licensing: Server Name, email address of the recipient of the SELECT Server license and the Serial Numbers to be added to the server.
Product activation is achieved by connecting to a SELECT Server, receiving a verification that your SELECT Server Name and Activation Key are correct, and successfully posting Usage logs. Product activation is not the same as checking out a license. This document describes how to configure AutoPIPE for activation. After initial configuration, AutoPIPE automatically and transparently tries to activate each time it runs, and runs unconstrained for a period of 30 days after its last successful activation. However, if activation is unsuccessful for a period of 30 days, AutoPIPE will not start until it is activated again.
Activating a product using the Product Activation Wizard
The Product Activation Wizard is designed to step users through the product activation process. After a product is installed, you must obtain a license and then activate that license. Obtaining the license alone is not enough to complete the process. This wizard eliminates the confusion and makes it clear that obtaining a license and activating a product are two essential steps.
The Product Activation Wizard opens automatically (unless the "Activate product using Bentley License Tool" check box is turned off) at the end of the product installation process. See the AutoPIPE Quick Start Guide for more information on installing AutoPIPE.
The first screen of the Product Activation Wizard offers four product activation options:
The wizard steps you through the activation process based on the options selected.
If you are not a Bentley SELECT subscriber and you are activating AutoPIPE, you are presented with three options:
I have a license file ready to import
  1. Enter the path to your license file (or Browse to the location of your license file) in the License File field.
  2. Click Next. The Wizard Selections dialog box displays the information provided on the previous dialog boxes.
  3. Review the information and click Finish to activate the product.
I have an activation key
  1. Enter the site activation key in the Site Activation Key field.
  2. If you are using HTTPS, enable the HTTPS (SSL) check box.
  3. If you are using a Proxy server to connect to the hosted SELECT Server, click the Proxy button and fill in the Proxy Server information then click OK.
  4. Click Test Connection to verify the connection to the SELECT Server.
  5. Click Next. The Check out license now? page displays.
  6. Enter your Email address in the Email Address field.
  7. Select the product to be activated (if not pre-populated) it the Product Name field.
  8. Enter the product version number (if not pre-populated) in the Product Version field.
  9. Click Next. The Wizard Selections dialog box displays the information provided on the previous dialog boxes.
  10. Review the information and click Finish to activate the product.
I do not have any license information
  1. The product will run in evaluation mode.
  2. Click Go To Bentley.com to request activation information.
Error History
AutoPIPE v9.6.2
The following outline identifies all major errors in Release of AutoPIPE v9.6.2.
TRADEMARK NOTICE
Bentley, the "B" logo, AutoPIPE, MicroStation, ProjectWise, SELECT, and MDL are either registered or unregistered trademarks or service marks of Bentley Systems, Incorporated, or one of its direct or indirect wholly-owned subsidiaries. Other brands and product names are trademarks of their respective owners.
COPYRIGHT NOTICE
© 2015, Bentley Systems, Incorporated. All Rights Reserved.
Including software, file formats, and audiovisual displays; may only be used pursuant to applicable software license agreement; contains confidential and proprietary information of Bentley Systems, Incorporated and/or third parties which is protected by copyright and trade secret law and may not be provided or otherwise made available without proper authorization.
Complete copyright information can be found in the product by choosing Help > About.
For reference, a copy of the End User License Agreement named "EULA.pdf" is included in the "AutoPIPE V8i SELECTseries5" folder of the product installation. By default, this location is "C:\Bentley\AutoPIPE V8i SELECTseries5".
Corporate Headquarters
685 Stockton Drive
Exton, PA 19341-0678 USA
Phone: (1) 610 458-5000
FAX: (1) 610 458-1060
WWW: http://www.bentley.com/
International Headquarters
Bentley Systems Europe B.V.
Wegalaan 2
2132 JC Hoofddorp
THE NETHERLANDS
Phone: (31) 23 556 0560
FAX: (31) 23 556 0565
WWW: http://www.bentley.com/nl-NL/
Asia Headquarters
Bentley Engineering Software Systems
Unit 1402-06, Tower 1
China Central Place, Beijing 100022
CHINA
Phone: (86) 10 5929 7000
FAX: (86) 10 5929 7001
WWW: http://www.bentley.com/zh-CN/
AutoPIPE V8i Select Series 5 Release Notes (09.06.xx.xx)
