Depending on which version you are using, the procedure may be slightly different:
| AutoPIPE CONNECT 11.00.00.22 and higher |
There are 2 ways to open the "Welcome to AutoPIPE Licensing" dialog
1. Using the ribbon
Select the File ribbon, and select the License group, Configuration command icon:
2. Using the drop down listing
Select the Application button in the top left corner of the screen and then select "License Configuration" command
| AutoPIPE CONNECT 10.xx |
AutoPIPE 10.01.xx.xx and lower only has one method of opening theĀ "Welcome to AutoPIPE Licensing" dialog
Select the "File" drop down listing, and then select "License Configuration" command
| AutoPIPE V8i 09.xx and lower |
