.net SDK Reference Guide
Table of Contents
Our .net Software Development Kit (SDK) is an interface to the OpenGround API that allows your applications to interact with the OpenGround platform.
It offers capabilities to programmatically perform querying, data manipulation, report generation, data transfer and configuration recall.
This reference guide details the relevant development concepts to help you get started with the SDK.
To obtain the SDK & Code Examples, please contact support.
Please also see this guide for general information on Getting Started with the OpenGround API.
Prerequisites
Prior to commencing development with the SDK, the following will be required:
Nuget packages are available for .net Standard v1.4, Framework v4.5 and v4.72. To obtain these and the code examples, please contact support.
Please see the Getting Started with the OpenGround API guide for more information about authentication, requesting a Client ID/Secret, obtaining your Instance ID/Region, and other topics.
Examples
Configuration
All SDK example methods are located in the Bentley.OpenGround.DeveloperNetwork.Examples project’s Program.cs.
These examples demonstrate how to use the SDK to perform functions within OpenGround. Where applicable, comments exist to explain how various operations are performed.
All examples assume you have valid credentials and the appropriate permissions.
Before running the samples, the following connection constants need to be configured in Program.cs inside the Connection Configuration region.
The methods below can be invoked from Main().
Please see this video for more information:
https://vimeo.com/529425441
Methods
Region Function Method
Authentication  Perform machine authentication (automated) PerformMachineLogin
Perform user authentication (interactive)  PerformUserLogin
Monitor authentication events ConfigureAuthenticationEvents
Perform logout  Logout
Projects Recall projects available to the user  GetProjects
Create a new project  CreateProject
Data Model Recall groups and headers within a configuration pack  GetConfigurationDataModel
Recall groups and headers within a project GetProjectDataModel
Documents Download borehole log template  DownloadDocument
Data Querying Perform query with filtering QueryProject
Templates Determine available report templates within a configuration pack GetConfigurationTemplates
Determine available report templates within a project  GetProjectTemplates
Configuration Retrieve system-level picklist groups and values  GetSystemPicklistValues
Retrieve project-level picklist groups and values GetProjectPicklistValues
Borehole Log Generate borehole log  CreateQuickLog
Log Report Generate log report  CreateLogReport
Section Log Generate section report  CreateSectionLog
Data Transfer Obtain transfer mappings for imports and exports  GetTransferMappings
Import AGS data  ImportAgs
Import CSV data  ImportCsv
Export AGS data  ExportAgs
Export CSV data  ExportCsv
Example Borehole Log Viewer Application
https://vimeo.com/529425851
