Is there a list of non-standard AGS 4 fields that have been added to the model
Question
In order to allow for all of the data to be included in OpenGround Cloud Professional, is there a list of all the extra 'non-standard' mapping that has been added to the system?
Answer
In some contracts such as the recent HS2 work in the UK, it has been necessary for a client to request for an AGS file with no added fields contained within from the AGS standard. OpenGround Cloud Professional includes a number of extra fields and mapping for other records that have been added to allow for more functionality in a number of ways. Any of the fields effected are listed below;
Explanation
OpenGround Cloud  Professional TableOpenGround Cloud Professional FieldAGS 4 Mapped Field
TestingScheduleDetailsTestCountLBST_TCNT
EnvironmentalContainerDetailsContainerIDECTN_ID
EnvironmentalContainerDetailsRemarksECTN_REM
TestingScheduleScheduleTypeLBSG_TYPE
ProjectOfficePROJ_OFFC
InitialConsumptionOfLimeGeneralSizePassingLSTG_SIZE
CompactionGeneralSieveSize1CMPG_SIZ1
CompactionGeneralSieveSize2CMPG_SIZ2
CBRGeneralSieveSizeCBRG_SIZE
LocationDetailsApprovedByLOCA_APPG
LocationDetailsCheckedByLOCA_CHKG
RelativeDensitySieveSize1RELD_SIZ1
RelativeDensitySieveSize2RELD_SIZ2
RelativeDensitySieveSize3RELD_SIZ3
MCVGeneralSieveSizeMCVG_SIZE
FlatDilatometerGeneralDepthTestDMDG_DPTH
FlatDilatometerGeneralRemarksDMDG_REM
FlatDilatometerGeneraltflexTimeDMDG_TFLX
FlatDilatometerGeneralChHorizontalDMDG_CH
FlatDilatometerGeneralDateTestDMDG_DATE
FlatDilatometerGeneralkHorizontalDMDG_DK
FlatDilatometerGeneralTestNumberDMTG_TESN
FlatDilatometerDataTestNumberDMTG_TESN
FlatDilatometerDataDepthTestDMDG_DPTH
FlatDilatometerDataMinutesElapsedDMDT_MINS
FlatDilatometerDataReadingDMDT_PTA
FlatDilatometerDataRemarksDMDT_REM
ShrinkSwellAirVoidsSHSW_AV
ShrinkSwellBulkDensityInitialSHSW_BDEN
ShrinkSwellAccreditionReferenceSHSW_CRED
ShrinkSwellDryDensityInitialSHSW_DDEN
ShrinkSwellShrinkSwellIndexSHSW_ISS
ShrinkSwellLaboratoryNameSHSW_LAB
ShrinkSwellMoistureContentShrinkSHSW_MCSH
ShrinkSwellMoistureContentSwellSHSW_MCSW
ShrinkSwellMethodSHSW_METH
ShrinkSwellParticleDensitySHSW_PDEN
ShrinkSwellRemarksSHSW_REM
ShrinkSwellCrackingRemarksSHSW_REMC
FlatDilatometerSeismicDerivedDilatometermodulusDMTP_DED
FlatDilatometerSeismicDerivedG0DMTP_DGO
FlatDilatometerSeismicDerivedHorizontalsressindexDMTP_DKD
FlatDilatometerSeismicDerivedK0DMTP_DKO
FlatDilatometerSeismicDerivedMaterialindexDMTP_DMID
FlatDilatometerSeismicDerivedOCRDMTP_DOCR
FlatDilatometerSeismicDerivedInternalFrictionDMTP_DPHI
FlatDilatometerSeismicDerivedqDDMTP_DQD
FlatDilatometerSeismicDerivedInterpretedsoildescriptionDMTP_DSD
FlatDilatometerSeismicDerivedCuDMTP_DSU
FlatDilatometerSeismicDerivedMDMTP_DVDM
FlatDilatometerSeismicDerivedInterpretationReferenceDMTP_REF
FlatDilatometerSeismicDerivedRemarksDMTP_REM
FlatDilatometerSeismicDerivedDepthTestDMTT_DPTH
FlatDilatometerSeismicDerivedTestNumberDMTG_TESN
RingShearDataAngularDisplacementRSHD_ADIS
RingShearDataBulkDensityInitialRSHD_BDEN
RingShearDataResidualStrengthCriterionRSHD_CRIT
RingShearDataDryDensityInitialRSHD_DDEN
RingShearDataDiameterInnerRSHD_DIA1
RingShearDataDiameterOuterRSHD_DIA2
RingShearDataAngularRateRSHD_DISA
RingShearDataResidualStressDisplacementRateRSHD_DISR
RingShearDataSpecimenHeightRSHD_HGT
RingShearDataVoidsRatioInitialRSHD_IVR
RingShearDataMoistureContentFinalRSHD_MCF
RingShearDataMoistureContentInitialRSHD_MCI
RingShearDataNormalStressRSHD_NORM
RingShearDataParticleDensityRSHD_PDEN
RingShearDataLinearDisplacementRSHD_RDIS
RingShearDataRemarksRSHD_REM
RingShearDataResidualShearStressRSHD_RES
RingShearDataStageNumberRSHD_TESN
FlatDilatometerSeismicDataCorrectedADMTT_APTA
FlatDilatometerSeismicDataCorrectedBDMTT_APTB
FlatDilatometerSeismicDataCorrectedCDMTT_APTC
FlatDilatometerSeismicDataDepthTestDMTT_DPTH
FlatDilatometerSeismicDataEffectiveVerticalStressEstimatedDMTT_EEFS
FlatDilatometerSeismicDataBulkWeightEstimateDMTT_EGAM
FlatDilatometerSeismicDataTotalVerticalStressEstimatedDMTT_ETVS
FlatDilatometerSeismicDataPorewaterPressureEstimatedDMTT_ISPP
FlatDilatometerSeismicDataThrustDMTT_MTH
FlatDilatometerSeismicDataAPressureDMTT_PTA
FlatDilatometerSeismicDataBPressureDMTT_PTB
FlatDilatometerSeismicDataCPressureDMTT_PTC
FlatDilatometerSeismicDataRemarksDMTT_REM
FlatDilatometerSeismicDataShearWaveVelocityDMTT_SWV
FlatDilatometerSeismicDataEstimationMethodDMTT_TECH
FlatDilatometerSeismicDataTestNumberDMTG_TESN
FlatDilatometerSeismicGeneralTestNumberDMTG_TESN
FlatDilatometerSeismicGeneralBladeCalibrationADMTG_BCVA
FlatDilatometerSeismicGeneralBladeCalibrationBDMTG_BCVB
FlatDilatometerSeismicGeneralCorrectionFactorDMTG_CFZM
FlatDilatometerSeismicGeneralSubcontractorDMTG_CONT
FlatDilatometerSeismicGeneralThrustMeasurementMethodDMTG_COT
FlatDilatometerSeismicGeneralOperatorsDMTG_CREW
FlatDilatometerSeismicGeneralDateTestDMTG_DATE
FlatDilatometerSeismicGeneralGroundwaterMethodDMTG_GWD
FlatDilatometerSeismicGeneralStandardDMTG_METH
FlatDilatometerSeismicGeneralReactionMethodDMTG_MRF
FlatDilatometerSeismicGeneralRemarksDMTG_REM
FlatDilatometerSeismicGeneralBladeNumberDMTG_REMB
FlatDilatometerSeismicGeneralSeismicNumberDMTG_REMS
FlatDilatometerSeismicGeneralRodTypeDMTG_TDR
FlatDilatometerSeismicGeneralRigTypeDMTG_TYPE
FlatDilatometerSeismicGeneralDepthGroundwaterDMTG_WAT
RingShearGeneralConditionRSHG_COND
RingShearGeneralAccreditionReferenceRSHG_CRED
RingShearGeneralLaboratoryNameRSHG_LAB
RingShearGeneralMethodRSHG_METH
RingShearGeneralResidualcohesioninterceptRSHG_RCOH
RingShearGeneralRemarksRSHG_REM
RingShearGeneralResidualFrictionAngleRSHG_RPHI
OrganicContentAccreditionReferenceORGC_CRED
OrganicContentLaboratoryNameORGC_LAB
OrganicContentMethodORGC_METH
OrganicContentOrganicContentORGC_OC
OrganicContentRemarksORGC_REM
AllophaneContentAllophaneContentALLO_AC
AllophaneContentAccreditionReferenceALLO_CRED
AllophaneContentLaboratoryNameALLO_LAB
AllophaneContentMethodALLO_METH
AllophaneContentRemarksALLO_REM
PinholeDispersionAccreditionReferencePHDC_CRED
PinholeDispersionPinholeClassPHDC_DC1
PinholeDispersionLaboratoryNamePHDC_LAB
PinholeDispersionMethodPHDC_METH
PinholeDispersionRemarksPHDC_REM
