How to create custom headers for log strips
 Product(s):OpenGround Cloud Civil 3D Extension
 Version(s):1
 Area:Profile Management
Explanation
It is possible to create Custom Log strip headers in AutoCAD Civil 3D. This tutorial explains how you can edit point labels to create custom headers for log strips shown on geotechnical profile views. Using the standard AutoCAD Civil 3D point label functionality you can specify how the text at the top of log strip should appear including using graphics to emphasise data.
Process
The following video will take you through the process required to create these.
https://vimeo.com/207090773
