How To Add Surfaces to an existing Geotechnical Profile View
 Product(s):OpenGround Cloud Civil 3D Extension
 Version(s):1
 Area:Profile Management
Explanation
You may have already created a Geotechnical Profile (section) but want to add an extra surface to it, i.e. current ground level, and an XYZ surface.
This tutorial will show you the steps involved in creating a Surface Profile and adding it to the Existing Profile View.
Process
By selecting the alignment you can then select the Surface Profile command to create a Profile for the alignment.
https://vimeo.com/166531137
