How to create a new header for field geology descriptions
 Product(s):OpenGround Cloud Civil 3D Extension
 Version(s):1
 Area:Data Management
Explanation
The following video will guide you through a process of using extra geology code fields (Geology Code 1, Geology Code 2, Geology Code 3) to help you define extra parameters (and descriptions) which in turn can then be used to improve your Civil 3D drawing and in particular the profiles and geology modelling.
Process
https://vimeo.com/164250754
