How to export/import Templates from one database to another
Explanation
If you wish to export a template from one database and then import to another please follow the steps below.
Please note that any templates that are imported / exported in this manner will not be editable within Template Studio.
Process
Note, before you start ensure your template you wish to export is saved to the configuration pack.
To now import that file into the other database, login to the database as the Administrator.
Following this the template will be in the system and ready to use.
