| Product: | AutoPIPE | ||
| First Affected Version: | 09.04 | ||
| Found in Version: | 11.03.00.10 | ||
| Fixed and Released in Version: | 11.04.00.xx | ||
| Area: | Flange Analysis | ||
| Severity: | High | ||
| Backlog Issue Number: | 890784 |
Program was incorrectly reporting zero flange stresses for both operating and gasket seating conditions if internal pressure was set zero. Program was not calculating stresses due to external loads.
This issue affects ASME section VIII Div1, Div2 and Appendix XI
Insert internal pressure to non zero value of 0.01 psi.
Program should calculate stresses due to external loads if internal pressure is set to zero.
Critical issues released in version
