| Version(s): | 08.05.01.25 | ||
| Area: | Levels | ||
| Subarea: | Level Display | ||
Turns off levels in level display, but the elements still show in the model.
Was turning of levels with level mode set to view display.
Did not turn off the level in the view that was active.
