| Version(s): | 08.11.09.459 | ||
| Area: | Groups | ||
| Subarea: | General | ||
| Original Author: | Jutta Eisenhauer, Bentley Technical Support Group | ||
Edit: Group - Ungroup missing
After updating SS2 to SS3 in the "Edit" menu the "Group" and "Ungroup" options are missing.
Remove old menu items
Old menu items from Version 8.5 have been set in the configuration (e.g. ustn.m01). Remove this items solved the problem
