| Version(s): | 08.05.02.35 | ||
| Area: | Cells | ||
| Subarea: | General | ||
| Original Author: | Jutta Eisenhauer, Bentley Technical Support Group | ||
Can't change ACS type
It is possible to change the auxiliary coordinate type while creating an
ACS, but not possible to change it in an existing ACS.
Change ACS type in 3D file
It is only possible to change the ACS type in a 3D file.
