| Version(s): | 08.11.09.459 | ||
| Area: | View | ||
| Subarea: | Saved Views | ||
| Original Author: | Carl Myhill, Bentley Technical Support Group | ||
I have repaired a file using the technique of referencing a bad file into a new one and copying the contents through, however the Saved Views are not copied, how can these be imported to the clean file?
Open the Saved View dialog in the new file
Select the ' Import Saved View ' tool at the top of the dialog and navigate to the bad file, highlight the saved view and select OK.
Resources
Recovering Corrupt DGN And DWG Files [CS]
https://bentleysystems.service-now.com/community?id=kb_article_view&sysparm_article=KB0026832
