Applies To | |||
Product(s): | MicroStation | ||
Version(s): | 08.01.02.15 | ||
Environment: | N\A | ||
Area: | Selection | ||
Subarea: | General | ||
Original Author: | Bentley Technical Support Group | ||
How to select Text whose Font ID is greater than 999. This is given that the Font form field will only accept an entry of 3 characters of less
Open Edit>Select By Attributes (this is important for the keyin to be recognized) Use keyin: selectby textfont <(><<)>value>
You can use this keyin to select all text in a file that contains a true type font (1135 being the font number in this example):
MDL SILENTLOAD SELECTBY;selectby type text;selectby type textnode;selectby textfont 1135;selectby textnodefont 1135;selectbyexecute
