| Version(s): | 08.11.07. 443 | ||
| Environment: | Windows 7 32 bit,Windows 7 64 bit | ||
| Area: | DWG | ||
| Subarea: | Open | ||
| Original Author: | Reginald Wallace, Bentley Technical Support Group | ||
When a DWG is renamed to anything other than DWG, it cannot be opened.
When attempting to open file error message received that file is not a
recognized file format.
To reproduce:
1. Select DWG file in either Open File Dialog in V8i or Windows
Explorer
2. Rename extension from .dwg to .dgn
3. Attempt to open file in MicroStation
Product: MicroStation V8i
Version: 08.11.07.171
Area: DWG, Problem ID#: 43501, ERRORMESSAGE
RealDWG work as design issue since AutoCAD cannot open any non-dwg (or
dxf) file extension.
