| Version(s): | V8 2004, V8 XM, V8i, V8i (SELECTseries) | ||
| Area: | Reference | ||
| Subarea: | N\A | ||
Undo commands done in a reference file is not available. For example, the ability to be able to undo changes on references to drawings. Reference move / reference mirror / reference rotate among other reference commands can not be undone.
Go to Workspace > Preference > Reference and uncheck "Save settings to Save changes"
