| Version(s): | 08.01.00.00 | ||
| Area: | Reference | ||
| Subarea: | N\A | ||
Losing reference attachments after they are attached and the master file is reopened
Check to make sure that MS_DISALLOWFULLREFPATH is not set. If set, MicroStation does not save the full path to references. By default, MicroStation stores both an abbreviated (portable) path and the full path to references.
This is applicable to all MicroStation V8.1 versions.
