| Product: | AutoPIPE | ||
| First Affected Version: | 09.01.00 | ||
| Found in Version: | 11.04.00.10 | ||
| Fixed and Released in Version: | 12.00.00 | ||
| Area: | All | ||
| Severity: | Critical | ||
| Backlog Issue Number: | 960482 |
SA182-F22 was deleted for ASME BPVC II-D 1998 and later editions. However, AutoPIPE’s ASME2000 and later material libraries continued to provide SA182-F22. Also, allowable stress, yield strength and design stress intensity values of SA182-F22 in AutoPIPE’s ASME2000 and later material libraries were different from those provided in ASME BPVC II-D 1992 edition. Using the allowable values from AutoPIPE’s ASME2000 material library for SA182-F22 may result in higher calculated allowable stress value as compared to allowable stress values provided by AutoPIPE’s ASME1992 material library.
To illustrate this defect, the following scenario can be considered:
Step 1: Create a new ASME NC 2010 edition model with English units
Step 2: Insert pipe properties with any name and dimension. Use the material SA182-F22
Step 3: Insert a pipe using the pipe properties created in step 2
Step 4: Set the temperature to 600 oF
Step 5: Review the input grid. Note that the allowable stress value is set to 20.4 psi
The correct allowable stress value for this material as per ASME BPVC II-D 1992 edition at 600 oF is 17.8 psi
The following considerations are provided to assist in your evaluation of the potential impact of this defect on the results:
Evaluate whether this defect has affected any existing models by considering the criteria below:
1. Was the model created or updated in program version 9.1.0 or later?
2. Was the material library selected for the piping code ASME2000 or later?
3. Was there a pipe ID in the model with pipe material SA182-F22?
A 'No' to one or more of the above criteria means that this defect does not affect the model’s results. No further consideration for this model is necessary.
Manually enter the correct allowable stress, yield strength and design stress intensity values.
AutoPIPE’s ASME2000 and later material libraries should not provide SA182-F22 material specification. Affected models shall update values of SA182-F22 to ASME BPVC II-D 1992 edition and set pipe material to non-standard ‘NS’.
“Pipe IDs with pipe material SA182-F22 are using incorrect values of allowable stress, yield strength, and design stress intensity due to previous program defect#960482. Would you like to review evaluation report?”
The contents of the critical error report shall be like the following sample critical error report:
Defect #960482 Evaluation Report---------------------------------Model Name: TEST1Model Version: 09.06.02.06Program Version: 11.00.00.17Report Filename: TEST1_960482.TXT---------------------------------For AutoPIPE’s ASME2000 and later material libraries, allowable stress,yield strength, and design stress intensity values for SA182-F22 areincorrect due to a previous program defect #960482. Please refer to thepublished defect report for more details, mitigation conditions andinstructions. To assist in the screening of this model for any potentialimpact by this defect, program has examined the model database and hasfound that allowable stress, yield strength, and design stress intensityvalues for the pipe IDs listed below may be incorrect and are updatedto ASME BPVC II-D 1992 edition. The impacted pipe ID’s material is setto non-standard ‘NS’.After saving this model or running any analysis in this version or latercommercial release versions, this screening will no longer be performed.Pipe IDs potentially impacted by this defect:-----------------------------------------------PIP1 PIP3
Critical and High issues released in v.12.00.00
Known Issues in AutoPIPE (Enhancements, defects, etc..)
