| Version(s): | 08.11.09.459 | ||
| Area: | Levels | ||
| Subarea: | Level Display | ||
| Original Author: | Jutta Eisenhauer, Bentley Technical Support Group | ||
If the commands "off by element" and/or "all except element" are set
in the level display dialog and a wrong element is selected it is not
possible to undo these commands (MS Standard toolbox).
Undo with "View previous" in the 2D View Control toolbar
