Critical and High issues released in AutoPIPE CONNECT v.12.00
960482
ASME Material Library: SA182-F22 values are incorrectly updated for ASME2000 and later material libraries
958453
ASME Material Library: Thermal expansion, Modulus of elasticity and Design stress intensity values for some pipe materials may not be correct
955880
ASME Nuclear Material Library: Thermal expansion and/or Modulus of elasticity values for some pipe materials may not be correct
939787
B31.4 and B31.8 material libraries are not updated in latest editions as per updates in source libraries
936789
ASME Libraries: Some pipe materials are not referring to correct standard material
Critical issues released in version
