| Version(s): | 05.07.01.22 | ||
| Area: | Hardware / Input Devices | ||
| Subarea: | N\A | ||
Wacom Tablet configuration
A client is trying to configure a digitizing tablet Wacom
Intuos 12x12, 5 buttons mouse, model # GD-1212-R to
be used with MicroStation SE. It is not working neither
with the tablet software or MicroStation Wintab.
Product: MicroStation SE
Area: Hardware / Input Devices
Using Wacoms driver 4.76-4 you can use it inside Microstation.
However you must set all buttons to Application-Defined except
the "Left-Button" for Data and the "Right-Button" for Reset.
The other three need to be set to Application Defined, otherwise
Microstation does not allow configuration of the buttons at all.
