| Version(s): | 08.09.04.51 | ||
| Area: | Reference | ||
| Subarea: | N\A | ||
Crash during True Hidden Line process.
MicroStation is crashing (closing unexpectedly) during the Hidden Line
Process when setting reference presentation to True Hidden Line.
Symptoms:
-Is not reproducible for all reference attachments.
-Appears to specific to certain attachments.
Product: MicroStation V8 XM Edition
Version: 08.09.04.51
Area: Reference, PROBLEMSOLVING
Enable "Facet All Surfaces".
The Hidden Line system can, at times, fail on problematic solid elements
in a given file.
1. After setting presentation to "True Hidden Line" (before starting the
process), click the magnify glass (Hidden Line Settings dialog opens).
2. Switch tab to "General".
3. Enable "Facet All Surfaces".
4. Click OK.
5. Process Hidden line presentation as usual.
