| Version(s): | 08.05.00.64 | ||
| Area: | Batch Processing | ||
| Subarea: | N\A | ||
Unable to select specific Models when using Batch Conversion.
Product: MicroStation V8
Version: 08.05.00.64
Area: Batch Processing
Model select filter was added in the XM versions for Batch
Conversion of DGN to DGN, not DWG.
